Create a folder browse dialog in script
royjuventus29
royjuventus29
[ FlexSim 22.2.4 ]
I would like to use script to create a folder browse dialog, then manually choose a relevant folder on the dialog and generate a file into this folder. Is it possible to create this folder browse dialog in script? Thank you!
JordanLJohnson
I think you are looking for the getdirbrowse() function:
https://docs.flexsim.com/en/24.0/Reference/CodingInFlexSim/CommandReference/Commands.html#getdirbrow...
Note that you need to pass a node with string data in. The node will be set to the directory the user chooses.
Jordan Johnson
Principal Software Engineer
