Crane Speeds vs. Travel Speeds
wproctorPG49C
Observer Observer
wproctorPG49C
Observer
Observer
[ FlexSim 20.2.2 ]
What is the different on a crane between the crane speeds and the travel speeds.
If, for example, I set the Gantry speed to 195 ft/min and the Max Travel Speed to 393.7, what speed does the crane actually move?
If, for example, I set the Max Travel speed to 195 ft/min and the Grantry speed to 393.7, what speed does the crane actually move?
philboboADSK
The speeds that are used depend on the Navigator that the crane is connected to.
By default, the crane isn't connected to a Navigator at all, so the "travel speeds" are grayed out because they aren't used.
If you connect the Crane (for example) to a Network Navigator, then those fields will be editable.
When the Crane travels on the network, it will use those speeds in combination with the speed limits on the network node edges.
When the Crane does offset travel that doesn't use the navigator, it will use its "crane speeds" because it is navigating itself.
You can test this pretty easily by using very large or very small numbers in order to see when different values are being used.
Phil BoBo
Sr. Manager, Software Development
Ben_WilsonADSK
Hi @william.proctor, was phil.bobo's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
wproctorPG49C
Observer
Observer
Thanks! Your explanation is helpful. In my case, it let me use both numbers (nothing grayed out). It was set to the "DefaultNavigator" and "Travel offsets for load/unload tasks". Therefore, since it is not attached to a network, I am assuming that it is using the crane speeds as you mentioned.
