cpallocate?
cpallocate?
steven_chen1
cpallocate?
steven_chen1
[ FlexSim 18.2.2 ]
Could you explain what this command does, and when may be used?
tanner_p
@steven.chen,
This might help:
steven_chen1
Is there a specific purpose to use the command?
Perhaps using the command to pre-allocate control point to occupy path as high priority agv? But I don't know what to do next to make agv travel to the control point.
cpallocate.fsm
tanner_p
@steven.chen
I've never personally needed to use this function, but as you probably know, control points can be allocated to AGVs for a number of purposes:
  • A point where AGVs pick up and/or drop off flow items.
  • A stopping point on the network where AGVs wait to enter an area or section of a path.
  • A decision point on the network where the AGV looks for work to do.
  • A decision point on the network where an AGV is dispatched to some other point on the network, dependent on network state/availability.
Maybe @jordan.johnson or @phil.bobo would have more to add.
philboboADSK
FlexSim is flexible. The cpalloc() command is available in case someone wanted to use it to develop custom logic for allocating control points instead of using the built-in options and features.
If you don't understand why you would want to dynamically allocate a control point with a command, then you should probably not be using that command.
I would suggest using Control Areas and the AGV Process Flow template instead.
Phil BoBo
Sr. Manager, Software Development
steven_chen1
Thanks for your answer.
So in the other hand, can the built-in allocation be disabled and use only cpallocate() by myself?
philboboADSK
No.
Phil BoBo
