Count Subtreenodes by Code
robin_brunner
robin_brunner
Hello Community,
my question is: How can I count treenodes by code? I want to count the connections in, out and center by code and save them into an integer.
int conin;
int conout;
int concenter;
conin = ??; //Number of Connections in.
conout = ??; //Number of Connections out.
concenter = ??; //Number of Connections center.
Does anyone know how to do this?
Regards, Robin
Matthew_Gillespie
The Object class has inObjects, outObjects, and centerObjects properties for accessing objects connected to the object with port connections. These properties also have a length property so you can look up how many objects are connected with each type of port connection.
Object obj = model().find("Queue1");
int conIn = obj.inObjects.length;
int conOut = obj.outObjects.length;
int conCenter = obj.centerObjects.length;
Matthew Gillespie
FlexSim Software Developer
robin_brunner
Thank you very much 🙂
