Copy processor state_cueeent properties to state_table
oceanbluesky1993
oceanbluesky1993
[ FlexSim 23.2.2 ]
Hello, I'm trying to copy the state_cueeent of profile properties to the state_table. It should be 21 properties after copied. However, the table showd 50 properties, and the exception keep showing that I have duplicate display name. Hope I can get some help, thanks!
state_current.jpgOEE.fsm
moehlmann_fe
What method are you trying to use to fill in the table. Using the sampling tool of the State Table on the processor and choosing the default profile should work.
If you want to get a 1-to-1 copy (without capitalized state names) then make a copy of the "state_current" node under the "state_profiles" node and choose that option when sampling the processor.
oceanbluesky1993
I want to build a OEE indicator. And I'm still following the instruction.20240829095633.png The error I encountered was fixed after I upgrade my flexsim version, thanks!
oceanbluesky1993
Btw, is there any other way to create OEE indicator without creating new status properties? Thanks!
moehlmann_fe
Depends what information you need for your definition of OEE. The object stores the times spent in each state, so if that is enough to calculate the OEE then you don't need any additional status profiles.
logan_gold
Hi @Keter, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
