Copy container labels to packed items after separator
amit_k2
Message 1 of 20
amit_k2
[ FlexSim 20.2.3 ]
In attached model, two pallets go through a combiner and are packed onto another pallet. The contained pallet of the combined pallet is then assigned a slot in the rack system. How do I correctly copy these labels to the packed pallets if they have to go through a separator as shown in the system, so that the individual pallets after the separator go to the location assigned to their container pallet?
Container_Label_to_Packed_Item.fsm
Replies (19)
Message 2 of 20
jason_lightfootVL7B4
You could put this in the processFinish trigger of the seperator if you alway know there are two pallets in the packed pallet.
createcopy(item.attrs["labels"],item.first.as(Object).attrs["labels"],1,0,0,1);
createcopy(item.attrs["labels"],item.last.as(Object).attrs["labels"],1,0,0,1);
Message 3 of 20
amit_k2
Do I remove the subflow after adding this trigger?
Message 4 of 20
Yes - or use that subflow with the logic above and don't put it on the trigger.
Message 5 of 20
amit_k2
Okay, I removed the subflow and put the logic on the separator's processFinish trigger. Separated pallets now have the slot and rack that the container pallet was assigned. So far so good. Now when moving these separated pallets to the rack, how do I currectly reference them? I used current as shown below, but it triggers exceptions.34995-1607445802597.png
What am I doing wrong and which part of the manual do I refer to have a better understanding of referencing for situations like this?
Many thanks for the help!
Message 6 of 20
Can you share the model ? Your descriptio doesn't match what you were doing in the last model where you assigned a slot to the inventoryPallet that contained the two pallets you're talking about.
Message 7 of 20
amit_k2
I'm sorry, I forgot to attach the model. Here it is.
Container_Label_Create_Copy_V_1.fsm
Message 8 of 20
Have you assigned them to the slot? If so you can just move them to the rack - they're in the array of Pallets labelled on your token.
But actually you've probably assigned the inventory Pallet which you're now not sending to the rack (right?) - so that will need unassigning. Not about the impact of unassigning an item that isn't yet in the rack - you'd have to try it.
Message 9 of 20
amit_k2
Yes, I assigned the inventory pallet a slot, which goes through a process before the rack, packed pallets are unpacked and then stored in the slot.
How do I unassign the slot of the inventory pallet? Do I do that in the same processFinish trigger, or in the process flow?
Message 10 of 20
Apparently you set the assignSlot to NULL - I put a link describing this in the last reply.
Message 11 of 20
amit_k2
Something similar to described in option 2 of the following from the manual? Container_Label_Create_Copy_V_2.fsm
Storage.Item.currentSlot
readonly Storage.Slot currentSlot
Description
The item's current slot.
The item's current slot is the slot that the item is currently stored in. You cannot directly set the item's current slot. Instead, you can do one of the following:
  • Directly set the item's assignedSlot and then move the flow item (either immediately or through some transit process) into that slot's storage object. Here when the item is moved into the storage object, the assigned slot will be recognized and its assigned slot will become its current slot.
  • Leave the assignedSlot property unassigned, and just move the flow item into a storage object. When the storage object receives the item, it will recognized that the item has no assigned slot, and will fire its slot assignment strategy, which should assign the slot. Then the item's assigned slot will become its current slot.
Message 12 of 20
No - it's the 5th option in the link I gave about the assignedSlot attribute as I stated. It states:
  • Directly set assignedSlot to NULL. This will put the item in an outbound state. Item searches using Storage.system.findItem() will skip over outbound items by default.
Message 13 of 20
amit_k2
Understood. Attached is the updated model. Can you take a look at it when you get a chance?
Container_Label_Create_Copy_V3.fsm
Message 14 of 20
Can you describe what you're seeing that is wrong at this stage? What have you now tried that isn't working or you don't understand?
Message 15 of 20
amit_k2
It is working the way it is supposed to. Just wanted to make sure that it has been implemented correctly. Thank you for being patient with me.
Message 16 of 20
I can't say as I don't have all the requirements. I thought you wanted pairs of items of the same type stored side by side in a bay in two adjacent slots. You seemed to move away from that with this model as it doesn't do that, and with previous versions where you put them together on a single pallet. If you understand both the model and requirements and think they match then that's a good start. Is that the case?
Message 17 of 20
amit_k2
Ideally, I would want them to be sent to the same adjacent locations after separation, and I had not noticed that they were being sent to different locations.
After close observation, the pallets have same destination till they reach Queue4 , but after that, they are sent to same painted slots, but in different racks if the query is
WHERE slot.storageObject.Active=1 AND Type IS $1.Type ORDER BY RAND()
So, I tried adjusting it to
WHERE slot.storageObject.Active=1 AND Type IS $1.Type  ORDER BY Type IS $1.Type DESC, slot.hasSpace($1.InventoryPallet) DESC
which results in exception of no slot assigned to the item. What is causing the issue here?
I am still trying to wrap my head around querying the storage system correctly.
Message 18 of 20
I feel inclined to say send us the requirements and process description and we can review what you're doing or need to do for the whole project - I feel I have as much of a grasp of that side of things as you probably feel you have with FlexSim's Storage System.
Message 19 of 20
joerg_vogel_HsH
You use clause “IS” where you should use “=“. You have problems with writing a SQL clause in FlexSim rather than with Storage System at all.
And it is absolutely impossible to help, as long as we don’t know what assigned $1 to.
Message 20 of 20
Ben_WilsonADSK
Hi @Amit Kulkarni, was jason.lightfoot's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
