CONV_INFO_ESTIMATE_CONVEY_TIME not depending on distAfterSource ?
david_besson
david_besson
[ FlexSim 16.2.0 ]
When I use the command "conveyorinfo" with "CONV_INFO_ESTIMATE_CONVEY_TIME", it seems that the parameter "distAfterSource" has not any influence. It should not be the case, right? Or I do not understand this parameter...
For example:
treenode DP1 = node("DP1", model());
treenode DP2= node("DP2", model());
double distAfterSource = 4.5;
return conveyorinfo(DP1, CONV_INFO_ESTIMATE_CONVEY_TIME, distAfterSource, DP2);
20161010-q-conveyorinfo-estimate-convey-time.fsm
Thanks for your help!
David
jeff_nordgren
@David Besson
David,
First off, the first parameter in the conveyorinfo() command should be a reference to the conveyor, not a DP as in your model.
Attached is your model with the reference changed to the conveyor. Is this what you were looking for?
q-conveyorinfo-estimate-convey-time-jn1.fsm
david_besson
@Jeff Nordgren
Thanks for your answer.
According to the documentation, the first parameter could be also an object that represents some point on a conveyor:
CONV_INFO_ESTIMATE_CONVEY_TIME(num distAfterSource, obj dest, num distAfterDest, num itemLength, num flags)( Estimates the time it will take to convey from one point in the conveyor system to another, including transfer times and assuming no blockage. This may be used in optimizing merge control logic for better slug release timing. In this query, the conveyor and dest parameters may be either a reference to a conveyor object, or an object that represents some point on a conveyor, such as a photo eye, decision point, entry transfer or exit transfer. distAfterSource and distAfterDest are offset distances from the associated point. itemLength should be the assumed item length. The flags parameter can either be 0, or CONV_ESTIMATE_STANDARD_SPEEDS. If 0 (default), the estimation algorithm will assume slug-build conveyors will convey at their slug release speed. If CONV_ESTIMATE_STANDARD_SPEEDS is defined, the estimation algorithm will use normal conveying speeds.
Anyway, even with the first parameter referencing a conveyor, the parameter "distAfterSource" has not any influence also...
philboboADSK
This is a bug. The function is not properly taking those offset parameters (distAfterSource and distAfterDest) into account in its calculations.
I'll add a note to the development list.
Phil BoBo
Sr. Manager, Software Development
david_besson
Ok, thanks!
