- Mute
- Permalink
- Report
[ FlexSim 21.1.4 ]
I am trying to create ControlPoint by code. The thing I want to make is to create ControlPoint in the same way as I can do manually by dragging the controlPoint and placing it exactly on the created Path, in this moment the controlPoint will have little cross inside him (a visual mark that the controlPoint lays exactly on the path). When I do this by code (creating an instance) and setting up the location of that controlPoint to be on the same path, but here the problem occurs. The controlPoint has the y-location as the path does, but the little cross does not appear. Only after moving manually with the controlPoint the little cross appears. I am dealing with this because I am creating the whole model by code and then the AGV network does not work because the controlPoint is not "connected" properly and you need to move it as I said a little and then the cross appears and everything works fine. I have attached the model with script to see what I meant.
Did anyone deal with this problem?
Thank you.
