Control AGV Count
Control AGV Count
priyankasgoudar33
Control AGV Count
priyankasgoudar33
[ FlexSim 20.0.10 ]
Hi, I want to control number of agv through dispatcher and not through process flow. Whenever I want only two agv running out of 5 I need to control it without disconnecting agv to dispatcher. How can I do it.
moehlmann_fe
I believe the simplest method would be to simply 'stop' the AGVs that are not supposed to be active. In the attached example I do so in the OnReset trigger of the dispatcher, based on the "numActive" label on it.
InactiveAGVs_fm.fsm
jason_lightfoot_adsk
Or close the AGV inputs.
priyankasgoudar33
@Jason Lightfoot can you explain this
The dispatcher passes jobs through its output ports to the AGVs' input ports. So you can have a similar effect by just closing those that exceed the number of AGVs by changing this line:
current.outObjects.stop(STATE_STOPPED);
to
closeinput(current.outObjects);
Jeanette_Fullmer
Hi @mary, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
priyankasgoudar33
@Jason Lightfoot great it works.
