Content limit in a Queue for different products
tobias_t2
Message 1 of 8
tobias_t2
[ FlexSim 19.2.1 ]
queue.fsmI would like to use one Queue for two different products. Besides, I would like to limit the content for both products. The Queue can contain 720 products (type 1) or 340 products (type 2). I failed to use one Queue and restrict the maximum content for the different products. I have two Queues in my model. Each product type has its own Queue. The problem is that the Processor fills the two Queues, although I would like to limit the content, because there’s not enough storage for both products. Is there a possibility to limit the storage for the different products?
Replies (7)
Message 2 of 8
cliff_king
One way would be to use the Pull Strategy and Pull Requirement fields of the Queue to control entry to the Queue based on the current number of each product type already in the Queue and the product type of the item trying to enter the Queue.
Another way would be to continue using two separate Queues for each product type, but then control flow into the two Queues using stopinput() and resumeinput() commands based on the total content of both Queues.
Message 3 of 8
tobias_t2
thank you a lot for your help! I don’t find “stopinput“ and “resumeinput“ in the pull settings oft he queue. Do I have to edit the code directly?
Message 4 of 8
tanner_p
The stopinput() and resumeinput() commands can be placed in Triggers or Custom Code activities (Process Flow). I've added an example of this in your model.
queue-update.fsm
Message 5 of 8
tobias_t2
Thank you very much for your example! Do I understand it right that your example was for one queue and I have to repeat the steps for the 3 other queues?
Message 6 of 8
cliff_king
Tobias, take note of the edits I made to my original reply because I made some corrections! Cliff
Message 7 of 8
tanner_p
@Tobias T2,
Sorry for the delayed response. You are correct. Because the Event-Triggered Source is listening to one queue ("Queue Product 2~2", as shown below), the token label "Queue" is only going to reference the queue that is listened to. You will need to set up flows to listen to and control the correct queues in addition to the one I made as an example.
Message 8 of 8
braydn_t
Did this answer help you? If so, could you please accept it? If not, could you let us know what else we can do to help you? Thanks!
