Without more info, it looks like something bad happened when you clicked on the add button for adding an event on the Event Listening tab of the Statistic Collector. If you could send a model, or replication steps to get this error, that would be great. We'll be sure to look at the issue before we move out of the beta phase.
@jordan.johnson apu2-final.fsm. When is it planned to move out of the beta phase?
Thanks!
This issue is actually related to a model update script bug in previous versions of the beta. If you upgrade to the latest 17.2 beta, and then open your 17.1 model, the upgrade script should work correctly. Once the upgrade script works correctly, you shouldn't see that error anymore.
The target release date is August 31st.
@jordan.johnson to update a model I just need to open it with the beta 17.2? If not could you please explain how to update it? I downloaded the 17.2 version today and open the model in the new version but I still get the error
Can you send your 17.1 model? I will look in to the update issue.
This model doesn't open in 17.1. To test this issue, I need one that was saved in 17.1.
@jordan.johnson sorry I only have those 2 version available.
Here's apu2-final-fixed.fsma fixed version of the first model you sent in. This should work great in the Aug 22 beta on.
