Conditional Port / Wait until condition is true
axel_z2
axel_z2
[ FlexSim 19.1.1 ]
Hello Community hello @Tanner Poulton @Jörg Vogel,
i have another Problem with my Simulation. When an engine is processed by the processor2 and it is finally finished with processing the engine can only go to queue4 when there is an engine on queue3. So i think i should use an conditional port for the processor and use something like a waituntil satement but it dont know how to do it....
can you help me there ?
best wishes
axel
version1.fsm
joerg_vogel_HsH
Currently there exists nothing as a FlexScript construct like wait until. FlexSim is simply event driven.
You can close the output of Processor 2. If the Queue 3 receives an engine, you can open the output of Processor 2. The event trigger is in Queue 3 OnEntry. If there isn’t a sequence of events, that you can always use, you can set OnEntry of Queue 3 a label for the entering engine, which you check OnProcessfinish of Processor 2. Then you can open the output of Processor 2 otherwise you are going to open the output of the processor when the engine enters the queue.
axel_z2
Hello Jörg, thank you very much! I post some screenshots in case somebody has the same Question.
best wishes
axel
