Concatenation of Names using SQL to Update Maps
ABajpaiWMKNX
Message 1 of 23
ABajpaiWMKNX
[ FlexSim 23.1.2 ]
Objective: To put unique names (in a map called "PartMap") of item that need to be summoned at each station. Each station has specific items that get added on top of the flow item "Floor".
I have 8 columns. Column 1 is stationID. Column 2 is MODEL_NAME. Column 3 MODE_PART and Column 4 onwards to column 8 are for options. Options header should be concatenated to the end of Model_Part if the the value in the row for that Model_Part under an option is "1". If it is blank, then no concatenation required. The nomenclature I am trying to achieve should be "MODEL_NANE-MODEL_PART-OPTION header" (OPTION is conditional if present)
Model and Part name columns have values in all rows but not the option names. Option names have only have one value "1". Columns 3 through 10 headers are the names of the options. If that option has a value 1 against the model name, that means that option is present in the model. For example, row 1 has a model name "Model 1", part name "Floor" and under column 3 option header "Option 1", there is the number 1 means that Option 1 is present in Model 1's Part "Floor". Another example, | Model 2 | Wall | 0 | then it should display "Model 2-Wall" since The Model_Part "WALL" does not have any options.1690471151403.png
@Jason Lightfoot
ChampionHomes_V7_Abhay_1.fsm
Replies (22)
Message 21 of 23
jason_lightfoot_adsk
Then don't hit apply all and just apply the code that you want to apply. The problem is with the NULL tab - it's not linked to a valid code node - so like the error message says - if you want to apply that code somewhere, copy the code and place it where you want before closing that window.
Message 22 of 23
ABajpaiWMKNX
Got it! If i "Apply all" it applied all the custom codes instead of just the one custom code that I am on, correct?
Message 23 of 23
Yes.
