Complex Manufacturing Example
shadow_holcomb
shadow_holcomb
[ FlexSim 22.2.0 ]
I have been working on a repair type shop example in FlexSim. Does anyone have a complex manufacturing example/download that I can look at to see where I am having issues?
Currently there is no batching, but a item will need to go through the same processor multiple times for different processing times. Also I have been trying to work the 3D model at the same time as building a process flow to match the 3D model.
I really need a complex example that has the 3D model and the process flow with no splits, joins or batching.
If you have any questions, please let me know.
Thank you,
Shadow Holcomb
Jeanette_Fullmer
Hello @Shadow,
I created a small sample model that shows how you can use a label and global table to set the variable process time based on the part of the cycle the item is at.
Process Time based on items cycle.fsm
In terms of a detailed demo model, you could reach out to Parker Standing.
Jeanette_Fullmer
Hi @Shadow, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
shadow_holcomb
Yes, this was very helpful in seeing how to use a label and global table to set the variable process times. I will have to take the time to create the variable table because I already hard coded all my processes times that are normal distributions.
Thank you so much for you help,
