Compatibility Issues with Version Upgrade
doris_c
doris_c
[ FlexSim 24.0.1 ]
Hello
I was using the old version 19.0.04 and upgraded to version 24.0.2 and it's different from version 19.
I've received help before as stated in the address below, but after upgrading the version, the AGV moves in a different way than that.
What's the problem?
https://answers.flexsim.com/questions/149148/supplying-taskexecuter-twice.htm
lintersection-order.fsm
moehlmann_fe
In the new version, redirecting the AGV causes another Pre-Arrival event that creates a second token for that AGV. (Which apparently did not happen in the previous version). Having two tokens per AGV messes up the logic.
As a workaround, you can add a zone that prevents the second token from being pushed to the list.
intersection-order_1.fsm
Jeanette_Fullmer
Hi @Doris C, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
