¿Cómo configuro prioridades cuando tengo muchos procesadores?
covadonga_fg
covadonga_fg
[ FlexSim 19.2.4 ]
Buenas tardes a todos,
Estoy desarrollando un proyecto pero me surge un error, use una prueba de prioridades con solo 5 procesadores, pero al momento de conectar más me marca un error.
Translated: How do I set priorities when I have a lot of processors?
Good afternoon everyone,
I am developing a project but I get an error, I used a priority test with only 5 processors, but when I connect more it gives me an error.
Could someone help me?
gokulakrishnan_k2
@Covadonga FG ¿Puedes compartir tu modelo para que sea fácil de entender?
jason_lightfoot_adsk
The problem is that the thing you were trying to load no longer has a reference. Check the point at which the task sequence was created and then if it exists at that point, check when that object is deleted.
Google Translate:
El problema es que lo que estabas intentando cargar ya no tiene referencia. Verifique el punto en el que se creó la secuencia de tareas y luego, si existe en ese punto, verifique cuándo se elimina ese objeto.
Ben_WilsonADSK
Hi @Covadonga FG, was jason.lightfoot's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept or comment back to reopen your question.
