Como aprender a configurar AGVS
alexandre_da_ds
alexandre_da_ds
[ FlexSim 20.2.0 ]
Como aprender a configurar o AGV para circular nessa rota?
Tenho um processo linear de entrega
O Carro manual leva de 10 a 12 latoes por volta?
No AGV da para simular qts latoes por volta?
O passador processa 1 lata a cada 5 minutos
jason_lightfoot_adsk
O Google tradutor não ajudou muito.
Você pode começar fazendo o modelo funcionar sem transporte (processo direto para processo), então fazer o tutorial AGV, e depois configurar seu modelo para usar o sistema AGV.
You could start by getting the model to work without transport (direct process to process), then do the AGV tutorial, and after that configure your model to use the AGV system.
Ben_WilsonADSK
Hi @Alexandre Da DS,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
alexandre_da_ds
Obrigado Jason
