Combining models
Combining models
rtsuge
Combining models
rtsuge
[ FlexSim 25.0.1 ]
A co-worker and I are creating smaller models of the different operational areas of a warehouse that will need to be combined into a larger model that will simulate a full warehouse. What is the best way to combine these models?
I've tried copying and pasting but the custom 3D visuals, which are saved on a network drive, do not appear. Ie. I have Processors where we changed the visual to a custom .skp file. The file path is still pointing to the network drive location, but the visual isn't appearing.
support5CRPZ
You need to save the custom visual shape file to the folder which the model is saved.
moehlmann_fe
Observer
Observer
You could look into splitting up the file using XML. It requires to be able to have 'borders' in the tree. But that can be achieved by using container objects and separate Process Flows.
This way multiple people can work on the same model in parallel, only comitting changes to their area of the model to a centrally saved master file.
https://docs.flexsim.com/en/25.1/Reference/DeveloperAdvancedUser/XML/XML.html
Jeanette_Fullmer
Hi @Russell T, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
