Combining models into single model
bcallaghan1
Message 1 of 8
bcallaghan1
[ FlexSim 21.2.4 ]
I have a few walls that I want to combine into a single model object so that I can rotate it and position it without having to move each part individually. Thoughts?
Replies (7)
Message 2 of 8
jason_lightfootVL7B4
Are they FlexSim Wall objects - from the Visual section:
Is it just the walls? (If so I will dig out a script that can write the definitions to a table and recreate them in one model).
Message 3 of 8
bcallaghan1
The original model was a cube but i upload a glass wall visual. That may mess with it though
Message 4 of 8
That sounds like it could be a task for an external CAD/modelling tool.
However if it's just to move as a group and rotate then you can add them to a visual tool or add them as drawsurrogate objects.
Message 5 of 8
bcallaghan1
Unfortunately that's what I was thinking as well. I can select numerous parts using ctrl and then clicking each part, but unable to rotate together.
Message 6 of 8
In the animation editor try adding them as drawsurrogate objects - it might be good enough depending on how you want to manipulate it afterwards.
Message 7 of 8
Jeanette_Fullmer
Hi @bcallaghan, was Jason Lightfoot's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
Message 8 of 8
support5CRPZ
@bcallaghan If you can use 23 update 2, USD object will be likely to be a solution.
email ID : support@flexsim.co.kr & support@simflex.co.kr
