Combine and separate two different color box
owen_liaw_h
Message 1 of 11
owen_liaw_h
[ FlexSim 19.0.0 ]
1645280546886.png1.fsm
hi, I don't know how to the combine the two different color box (brown [1] and black[2]) (different length) to one box (they are attached together become more longer)(length 1 + length 2) such as the figure above 1, the drawing (black and red). After that, the separator to two conveyor, it still cannot work... could someone help me?
Replies (10)
Message 2 of 11
joerg_vogel_HsH
Please Update to an actual supported Version. Thanks!
Message 3 of 11
owen_liaw_h
u mean update to newest version, sir?
Message 4 of 11
owen_liaw_h
someone pls help me
Message 5 of 11
joerg_vogel_HsH
It is a matter of position. A packed item consists of a Container and packed items in it as subnodes items. You need to adjust the subnode item location in a trigger like Prozessfinish.
item.first.as(Object). location=Vec3(1,2,3);
Where 1,2,3 are values for x,y,z in relation to item. You will try different values to meet your requirements.
Message 6 of 11
owen_liaw_h
Sir, im sorry, i still not understand what sir mean about the subnodes items... Then, i just add the code to the triggers on the subnodes items?
There are two sources produce different length of the box then attach together in vertical direction
Message 7 of 11
jason_lightfootVL7B4
The suggestion is that you change the combiner from 'batch' to 'pack' which will result in one flowitem leaving that contains the other. Jorg is suggesting that you position the 'packed' item so that it looks like it is joined to the other item (using a combiner trigger or using a flowitem packing method).
Message 8 of 11
owen_liaw_h
i try to change the batch to pack and used combiner trigger (process finish) for code, but still not work...
Message 9 of 11
chanykE2WUT
Please update your version to latest. We are aware that you are NOT using a legal version to ask question at this platform. Please note of the legal impact toward you
Message 10 of 11
owen_liaw_h
yea, because i used my friend laptop to do this work.. Sorry, i will go install actual version
Message 11 of 11
owen_liaw_h
Sir, can u do one more example for me by using this code
