Collision problem
Collision problem
a9080109
Message 1 of 45
Collision problem
a9080109
[ FlexSim 20.0.10 ]
I want to know how to use pf to control the time of collision, so that I can collect data
agv-avoidance-rc.fsm
Replies (44)
Message 2 of 45
jason_lightfoot_adsk
Detect the OnCollision event in an eventTriggeredSource activity and then use a StatsCollector to collect the data.
Message 3 of 45
a9080109
But what I want to do is I want to give the collision time like five seconds, can it be done with PF?
Message 4 of 45
I don't understand your sentence.
Message 5 of 45
a9080109
i mean when the collision happens i want to use pf to give the whole process a delay time
For example I only want the collision to end after five seconds, is this controllable?
Message 6 of 45
a9080109
@Jason Lightfoot
Can you tell me if you have any good suggestions?
Message 7 of 45
You know:
  • how far apart the transporters are
  • the size of the spheres
  • the velocities.
so from that you could calculate the duration. If you want to have the collision last for a certain time then you'll need to solve it using basic algebra.
Message 8 of 45
a9080109
Can you provide a case? For example 1 second?
Message 9 of 45
It's time = distance/speed - you should be able to manage that.
Message 10 of 45
a9080109
I don't understand how do I bring data into flexsim
Message 11 of 45
It occurs to me now that you might just want to hold the AGVs for 5 seconds before they continue once the collision event has been detected - and not that you want the spheres to be colliding for exactly 5 seconds - is that right?
Message 12 of 45
a9080109
yap is to stay in that state for five seconds, after which it will continue to execute the task
Message 13 of 45
Okay so you should probably just stop the AGVs for the 5 seconds when you detect a new collision. If you have a problem with double detection then you'll need to record that the two AGVs are in a collision already and test for this when the second firing of the collision event happens.
Message 14 of 45
a9080109
I don't know very well!! Could you please give me an example?
Message 15 of 45
Message 16 of 45
a9080109
@Jason Lightfoot
I would like to ask if I am going to add other objects now, how can I adjust my model to make it run smoothly. Also in the TRAVEL settings, can I do it in another way? Instead of using CURRENT.DEST to specifyagv-avoidance-rc-jl.fsm
Message 17 of 45
Of course - add the other agvs to the same process flow. See instanced process flows. You already know how to create travel tasks - the example just used a label for ease.
Message 18 of 45
a9080109
@Jason Lightfoot
I used the case you provided to create a similar activity in general pf, but he doesn't seem to have a way to delay like in the case, what's wrong with me?0421.fsm
Message 19 of 45
a9080109
@Jason Lightfoot
In addition, I also want to ask if I can control which side will back up when a collision occurs? As far as this model is concerned, the car on the left is backing up
Message 20 of 45
You're using the term 'current' in a general process flow. It doesn't mean the same thing there. You need to write a pointer to the agv on the token using the event triggered source.
