Coding in flexscript
j08j
j08j
[ FlexSim 24.0.2 ]
I have some questions about flexscript coding, how can I execute these steps using flexscript?
1. How to uncheck ”Fire OnResourceAvailable at Simulation Start" in the TaskExecuter panel?screenshot-2024-04-14-at-114838-am.png
2. How to add array label, edit the row number and the number in the array?screenshot-2024-04-14-at-114905-am.pngscreenshot-2024-04-14-at-114951-am.png
3. About the list properties, How can I delete those two expression field? I just want to leave "bound". Also, every time I re-execute the program, I hope to re-create TSList1 instead of continuously generating TSList2, TSList3,..., what can I do?screenshot-2024-04-14-at-114805-am.pngscreenshot-2024-04-14-at-121122-pm.png
Thank you very much in advance.
arunTTT2P
Object ASRSVeh = Model.find("ASRSvehicle1"); // AsRS Vehicle Ref
ASRSVeh.setProperty("AvailableOnStart",0); // 1 for checking and 0 for unchecking the checkbox
The set property was found in the property table.
https://docs.flexsim.com/en/24.1/Reference/Tools/PropertyTables/PropertyTables.html#app
ASRSVeh.LabelArray = [1,2,3];//LabelArray is the labelname
For array operations refer the Flexscript API's
FlexScript Class - Array (flexsim.com)
treenode GlobalLists = Model.find("Tools/GlobalLists"); // Removing all tasksequence lists
//Before creating new
for(int i=1;i<=GlobalLists.subnodes.length;i++)
   string ListType = GlobalLists.subnodes.find(">variables/listType").value;
   if(ListType == "TaskSequence")
      GlobalLists.subnodes.destroy();
treenode list = Tools.create("List","TaskSequence");// Tools API
treenode focus = list;
string fieldTypeName = "ExpressionField";
treenode newField = function_s(focus, "addField", fieldTypeName);
newField.name = "bound";
treenode Expression = newField.find("expression");
string Code = "/**Custom Code*/ Variant value = param(1);\
   Variant puller = param(2);\
   treenode entry = param(3);\
  double pushTime = param(4);\
   return 5;";
   Expression.value = Code;
 list.find(">variables/fields/age").destroy(); // Removing first two fields
 list.find(">variables/fields/distance").destroy();
moehlmann_fe
Rather than removing the tow default fields, you can also just create a general list instead. The only difference between the list types is what fields they possess by default and which fields are available to add via dropdown menu.
j08j
Thanks for the clarification!
