Chosen Staff for Global Process
tiffany_pecson
tiffany_pecson
[ FlexSim HC 5.3.4 ]
Is there a way I can view which staff was chosen for a Global Process if the Staff Requirements chooses Any member from an an Alternate Group with multiple Staff without having to watch the simulation?
Would I have to do a code snippet to get a recording or could there be a dashboard that counts the number of times that a staff member has to do that certain global process?
Matthew_Gillespie
I'm not sure what the best way to do this is, but I'm attaching a model with two different ideas I had.
The first uses a Data Collector to record the allocated staff whenever an activity in the global process finishes. Then a dashboard displays the information collected by the data collector.
The second uses Activity Finished triggers on the global process activities to print the allocated staff to the output console.
staffusedbyglobalprocess.fsm
Matthew Gillespie
FlexSim Software Developer
tiffany_pecson
The Data Collector was exactly what I was looking for, thank you! I didn't know there was a Data Collector option and that is very helpful.
