Check video recorder specifications
tsuji_ryusuke
tsuji_ryusuke
[ FlexSim 23.0.11 ]
Record one 3D model and one dashboard using a shared sequence. At this time, if both are set to inherit the size mode, the recorded data will appear black and will not be recorded correctly.
Is this by specification or a bug?
kavika_faleumu
Hey @Ryusuke T, this seems to have been a bug that has been fixed in v24.0. I was able to replicate your issue in v23.0, but recording a simple model works fine in v24.0.
tsuji_ryusuke
@Kavika F ,
I also checked with v24.0 and confirmed the fix. Thank you for your answer.
