Check if a conveyor segment is connected to a previous and a next segment
guiroehe
guiroehe
I am looking for a script to check if conveyor segments in a network have a previous and/or a next segment connected to them. As conveyor segments might have multiple "previous" segments or other decorations (decision points, etc.), I am not sure about hot to scan through the conveyorPoints to get the proper classification.
Thank you.
moehlmann_fe
Due to the use of "sdt" values this is not guaranteed to work in other version, but should do so in the current one:
If the ownerobject of the node the conveyor point links to is a conveyor (determined by checking class name), then it represents a transfer.
Based on whether it's a side transfer for either conveyor and the distance along the conveyors' length I infer if it is an incoming or and outgoing connection.
One caveat: Since it uses the position of the transfer, some designs will break the logic, like having an outgoing connection at the very start of a conveyor.
guiroehe
Thank you, @moehlmann_fe,
I wonder why conveyor connections are not treated as In and Out objects, and other decorations (decision points, etc.) as central objects. Or, at least, a similar structure.
Thank you for your continuous and kind support!
