Chart vs target
Chart vs target
lambert
Chart vs target
lambert
[ FlexSim 22.1.2 ]
Hi, is there any chart to visualize KPIs versus predefined targets?
Something like this:
Thank you,
Lambert
moehlmann_fe
Observer
Observer
The closest I could come up with is a stacked bar chart in which the bar sizes are calculated so the end position of a 'target bar' stays constant. To show the 'value', you'd use two distinct bars. One to show the value if it is below the target (this will get set to zero ones the value surpasses the target) and one if it is above (this is zero as long as the value has not reached the target). This allows the order of the 'value' and the 'target' bar to switch when the value increases/decreases past the target. It also allows to choose different colors.
targetchart.gifThe statistics collector feeding this chart just needs access to the current KPI value and the corresponding target for each row.
target_barchart_fm.fsm
lambert
that looks great thank you
