Changing Load animation
ilaria_b
ilaria_b
[ FlexSim 16.1.2 ]
I would like to have a different animation for load task. I would like to have an operator that pushes (or walks near) the object loaded. The objects i'm processing in the model are too big to be carried out by the operators.
I tried to delete the walkloaded animation of the operator, but the object still flies.
joseph_g3
@Ilaria B
There are operator push animations in FlexSim, but they are only available in version 18.0 and above. The best solution would be to either use a more recent version of FlexSim and use the push animation or use a "Change Visual" activity to make the loaded object appear on the floor in front of the operator. For example:
You can then adjust the offset values as needed.
joseph_g3
@Ilaria B
Was my answer helpful for you? Do you have any further questions?
ilaria_b
Yes, thanks so much for your help!
Ilaria
