Change the horizontal axis of the graph from seconds to minutes
hoooo
hoooo
[ FlexSim 23.0.8 ]
Hello.
I would like to change the units of the horizontal axis of the status bar graph on the dashboard from seconds to minutes.
If the time unit is set to seconds in the model settings when creating a new model, is it possible to set the horizontal axis unit of the graph to minutes?
please tell me.
thank you.1124.fsm
joerg_vogel_HsH
@hoooo, have you looked thoroughly through all properties of your chart? I think there is an option to change units in some charts.
hoooo
@Joerg Vogel I looked for the properties but couldn't find it.
joerg_vogel_HsH
Hello @hoooo,
I couldn't find an option field, either. You can adjust the statistical collector data gathering, but you have to install the statistic collect on Advanced pane at the bottom of properties first. Then you get an Data pane on top of your properties. On this pane you get to the statistic collector by (1) of picture below. Then you change to Columns (2) tab. You select Time (3) and you edit at end of line value (4) "/60"
statistic-collector-manual-to-minutes.jpg I think Jason Lightfood or Felix Möhlmann find a better solution later today.
hoooo
Hello. @Joerg Vogel
Thank you for teaching!
I was able to convert the horizontal axis into minutes!
