Change process time dynamically according to MaxLT
filippo_a1
filippo_a1
[ FlexSim 18.1.0 ]
Goodmirning,
I working on a process that every 20 minutes checks the process speed and changes it according to 2 cases: 1. process time is too high; 2. process time is too low. Is there a way to replicate this in Flexim? In the model below i created a process made by 1 source, 2 queues and 1 processor.
The processor is set at process time: PROCESSTIME_NORMAL, defined in global macro.
In the source i defined an arrival schedule of 10 items with ArrivalTime and Max_LT, where
(Max_LT) - (ArrivalTime) is the LT planned for each item to arrive at Queue2.
how can i tell the model to compare Max_LT with the processor end time for each object and tell it to change speed according to defined global macros?
different-process-time.fsm
Thanks very much in advance
jose_antonio_mad
Hello @Filippo A,
I attached a model with the solution.
What I do is compare the current time with Max_Lt on entry and based on that, select a value in the Process Time of the processor.
I hope I've been helpful.
13069-different-process-time-solution.fsm
tanmay_varshney
13069-different-process-time.fsmHello @Filippo A,
I have attached a model as per understanding your query.
kindly look into it , I suppose it will solve your problem
