Change 3DS Object Color
alexander_muff
Message 1 of 10
alexander_muff
[ FlexSim 16.2.0 ]
I have a imported a 3DS to represent my flow item.
I would like to change it's color as it progresses through the model. See attached example. In object2 I'd like to change it to red.
Also, what's the best way to index through changing 3D objects? for example, an assembly adding parts as it progresses through its build.
Replies (9)
Message 2 of 10
sam_stubbsYXX86
I don't see the attached file you mentioned.
Message 3 of 10
alexander_muff
Message 4 of 10
rodrigo_lamas
I don't know why some imported shapes can not change the color in the normal way. It happened with me too. But in your case I think That You can use the standard box and change the length to 3x2x1.
Message 5 of 10
alexander_muff
This shape used was just a quick example. Is there a better file format? I am using 3DS from Sketchup.
Message 6 of 10
rodrigo_lamas
I think that 3ds is the best format, but *.stl and *.wrl (from solid and pro-engineer) are good too.
Message 7 of 10
alexander_muff
Is there a good way to change to a new 3DS file? THere is a warning about slowing down your model.
Message 8 of 10
joerg_vogel_HsH
Part 1 Certainly you have looked into the manual here
Otherwise your question was asked long before this forum exists. You find some more information in the old community forum. Phil Bobo is an respected author of many absolute useful posts. The search keywords should contain his name and color there. Other keywords are invis and ac3d.
Message 9 of 10
joerg_vogel_HsH
Part 2.
If you have an assembled product you could use the method of Shape Frames.
Message 10 of 10
joerg_vogel_HsH
Be aware of using wrl exports from ProEngineer (Wildfire, Creo) the default export version is 2.0. The export version has to be changed to 1.0 wether in the export option or in the config option (config.pro, config.sup).
