Cannot open MTBF-MTTR interface
allen_greenwood
allen_greenwood
[ FlexSim 17.0.13 ]
I cannot open the GUI for any MTBF-MTTR in the attached model. I can edit the MTBF-MTTR parameters from the Tree, but in the case of one of the MTTRs, it is 0.00 and I want to add a code snippet.
Also, I want to use this model in 2018 Update 2 but is that possible due to the change in the MTBF-MTTR structure?
downtime3-stepprocess.fsm
philboboADSK
Change the guifocusclass attribute of your MTBFMTTR objects from
VIEW:/pages/MTBFMTTR Parameters
to
VIEW:/pages/tools/MTBFMTTR Parameters
"Also, I want to use this model in 2018 Update 2 but is that possible due to the change in the MTBF-MTTR structure?"
I don't understand this question. Is there a reason why you think this is not possible? Have you tried it?
"but in the case of one of the MTTRs, it is 0.00 and I want to add a code snippet."
It looks like the node MODEL:/Tools/MTBFMTTR/mm_BreakDowns>variables/mttr was explicitly given number data in the tree (probably by accident). You can fix this by clicking on it in the tree and pressing the T key to give it text (string) data.
Phil BoBo
Sr. Manager, Software Development
