Cannot bind to Python function
mischa_spelt
Advisor Advisor
mischa_spelt
[ FlexSim 22.1.0 ]
The ability to connect FlexSim and Python looks really cool so I decided to make a simple test case. Rather than controlling FlexSim from Python I first decided to see if I can call a function from FlexSim.
I created a Test.fsm model and put a simple Python script in FlexSimPy\FlexSimPy.py. But when I try to call the Python function I get
exception: Code Binding Error: could not bind to function
Node: /Tools/UserCommands/Add/code
Binding string: external python "FlexSimPy/FlexSimPy" "add"
Windows Error Code : 126
As far as I can see code 126 means missing DLL, but according to the GitHub documentation,
The PyConnector project implements the ability to bind the evaluation of nodes in FlexSim's tree to the evaluation of python functions. The project is implemented to work with python versions 3.7, 3.8, 3.9 and 3.10. The output DLLs from this project are included in the installed version of FlexSim.
(emphasis mine) and I found the DLLs in program\python so I assumed this should work out of the box.
I set the Python version in Global Preferences and made sure that python.exe is on my path. What am I missing? 🙂
mischa_spelt
Hmm, it actually seems to work if I don't put the Python module in a subfolder of the model directory. Did I misread the docs that this should be possible?
anthony_johnsonT83CM
This is similar to this stack overflow question. First, you need to use dots instead of slashes as your path separators. So your module specifier should be "FlexSimPy.FlexSimPy" instead of "FlexSimPy/FlexSimPy". Second, in the folder where you put your FlexSimPy.py file, you need to have a blank file called __init__.py. Placing that file there signifies to python that this is a 'submodule' folder, so it can find the appropriate files.
I'll update the documentation to reflect this.
mischa_spelt
Thanks, dot-instead-of-slash did the trick!
The __init__.py does not seem to be strictly necessary but I'll include it anyway as part of a proper Python module.
guillem_f
I've followed all your steps, but I'm still having trouble binding my python function. I am getting the exact same error as Mischa, and neither the dots for subfolders nor the __init__.py seem to solve it.
The only thing I can't find is the "made sure that python.exe is on my path" part. May this be causing errors? Otherwise, am I missing something else, like downloading the github files?
Thanks in advance!
pymod.py
python-test.fsm
jason_lightfoot_adsk
Isn't the path reference just to your systems environment variables?
mischa_spelt
I am not sure if this was needed, but I did it anyway. To test if you have it on your PATH, open a Windows Command Prompt from the start menu and type python. If it says "'python' is not recognized as an internal or external command" you can add it to the path. I pulled Python from my Visual Studio installation and had to add the following folder to the path: "C:\Program Files (x86)\Microsoft Visual Studio\Shared\Python39_64".
