Can we create a background thread in FlexSim that do some tasks once a second?
yue_y
Message 1 of 22
yue_y
[ FlexSim 19.1.0 ]
I want to create a thread and let FlexSim report some data to another server once a second. Is it possible to create a separate thread that does this job?
Replies (21)
Message 2 of 22
Jacob_Gillespie
To create a thread you would have to use C++. See this answer for an example of using a thread.
You might be able to do this with the setticker(node thenode[, num tickspersecond]) command.
Message 3 of 22
yue_y
Thank you Jacob, any tutorial on writing C++ in FlexSim?
Message 4 of 22
yue_y
Also, I am not looking for the exact thread concept. Anything with the behavior that executes a FlexScript snippet once a second on the side is enough
Message 5 of 22
Jacob_Gillespie
@Yue Y That's what setticker() does. It executes a flexscript / cpp node x times per second.
Message 6 of 22
yue_y
Is this command executed separately from the the simulation process? Will it block the whole simulation?
Message 7 of 22
Jacob_Gillespie
Yes it will block
Message 8 of 22
yue_y
Will it block between two execution or it will only block during execution?
Message 9 of 22
Jacob_Gillespie
It will block only during execution, not between.
Message 10 of 22
Jacob_Gillespie
Message 11 of 22
yue_y
Could you give an example of using setticker? Especially what does the first parameter look like?
Message 12 of 22
Ben_WilsonADSK
Hi @Yue Y,
Please find attached a sample model showing usage for setticker(). In my testing, it appears that the tickspersecond parameter must be >=1.
Call setticker() after the model run has started - for instance on some object or model trigger, or on a scheduled user event.
setticker-example.fsm
Message 13 of 22
yue_y
Thank you Ben! I am running the example you provided, is there a way to stop this script programmably or manually?
Message 14 of 22
yue_y
I found it in the user manual:
setticker(0) can be used to turn off the execution
Message 15 of 22
yue_y
Hi Ben @Ben Wilson, how did you add the ticketLogic in Tools folder?
Message 16 of 22
Ben_WilsonADSK
Hi @Yue Y,
Here is how I added a new node into the Tools folder (via right-click on the Tools node, but would work for any parent node):
Here is how I added ability to add text to the node:
Here is how I toggled the node to be a FlexScript node:
Message 17 of 22
yue_y
The command executes the node for "tickspersecond" times every second of physical time. Is there any similar function that works for simulation time(eg. execute once every 5 simulation time units)? I am considering using physical time x speed in this function but if the simulation is stopped or blocked, this function will still be executed. Any other command that I can use?
Message 18 of 22
philboboADSK
If you want to repeatedly execute a function in simulation time, use a repeating User Event:
Phil BoBo
Sr. Manager, Software Development
Message 19 of 22
yue_y
Could you please give an example of creating an user event that can execute custom code repeatedly in FlexScript? Thank you!
Message 20 of 22
philboboADSK
I did in the screenshot above. It executes the Event Code repeatedly.
  • Add a user event
  • Check the "Repeat event" box
  • Specify the Repeat Event Time
  • Edit the Event Code
This is a standard toolbox item. You just use it. No example is needed.
Phil BoBo
