Can I set the object Max Conent using code ?
kamil_ks
kamil_ks
[ FlexSim 19.0.2 ]
I was looking in the Tree but there was only possibilites to get max content value from the model. Is there any possibility to set max content value from table e.g on model reset ?
joerg_vogel_HsH
It is a variable in the tree. Then you can set the variable value. If you change this value and you use the transport option to get flow items into the object, please take into account that this variable is evaluated in the combination of the variable "nroftransportsin".
kamil_ks
What command should I use to set this variable ? For example I want to set maxcontent of this variable below for 6.
model().find("BL4>variables/maxcontent") = 6
joshua_s
This is an example for changing the max content of a queue
getvarnode(Model.find("Queue1"), "maxcontent").value=6;
