Can I put "ORDER BY ASC" or "ORDER BY DESC" conditional?
pinakin_k
pinakin_k
[ FlexSim 20.2.3 ]
In my application i want to make the order ascending or descending based on the condition at the pull. is it possible to do than in the Pull From List activity?
joerg_vogel_HsH
perhaps you can do it in a previously activity and parse it as $ parameter into a query by a label.
Or you concatenate a string to parse in a query for a custom code.
jason_lightfootVL7B4
I've done this using a decide activity sending a token to one of two pulls - one that does ASC, the other DESC - which is simple.
If you want it in a single pull activity you could ORDER BY myexpression ASC and have myexpression as an additional field on the list that is some value multiplied by a pullers label value (eg. ascmultiplier) which changes between 1 and -1 depending on whether you want ASC or DESC.
So the expression could be something like this:
value.sortcriterion*puller.ascmultiplier
Ben_WilsonADSK
Hi @Pinakin K, was jason.lightfoot's answer helpful? If so, please click the red "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
pinakin_k
@jason.lightfoot
Thanks!
I just returned the Query string in the pull Query as ASC or DSC depending on the condition. It also works.
