Can i make the people not stand on top one another?
socojim
Message 1 of 8
socojim
[ FlexSim 22.1.1 ]
I'm trying to get a decent visual for shooting of a video that shows what an elevator lobby would "look" like at various levels of hospital census. When using the elevators, a waiting line, and upstairs acquirable resources, things act as they should statistically....however, once a resource is able to acquire their location upstairs, they'll leave the waiting line and stand in front of an elevator car....but everyone else that gets their resource as well will also do this and they all stand on top one another. Is there an "easy" way to get them to spread out a bit and respect each others space a bit without delving into the agent module? Thanks in advance!
Replies (7)
Message 2 of 8
JordanLJohnson
Depending on how you model a situation, there may be some model-specific things we can do to make things look a bit better.
But in general, no, there's not a way to do that without using the Agent module. There is one checkbox on the AStar navigator that says "Ignore inactive members." Basically, this makes it so that people who aren't travelling don't cause collisions or re-routes. Perhaps try unchecking that box? Note that this can make deadlock issues more likely, and they probably won't act like a natural crowd. If it's a critical component of the simulation, then using Agent is the way to go for now.
Jordan Johnson
Principal Software Engineer
Message 3 of 8
philboboADSK
You might get a better answer if you posted a small sample model demonstrating the problem that people can open and modify.
If you ask a general question with a generic description of the problem, you are likely to only get a general answer with a generic description of possible solutions.
Rather than posting a description of how you built a model, please post an actual sample model demonstrating the problem.
No one can tell you an "easy" way to fix a problem if they first have to divine what your problem actually is and try to build it based on your description instead of just opening a model and pressing run.
Phil BoBo
Sr. Manager, Software Development
Message 4 of 8
socojim
Fair point Phil, my apologies. Model attached. You'll notice what im talking about when they come out of the waiting line and get to the elevator. Obviously there are alot of ways around creating these types of visuals without using Flexsim verbatim, but rather incorporating some post editing techniques in other software to fade in a herd of people with he right head count that looks good, etc....but as Flexsim advances, i'm trying to use it for as much of this stuff as i can when it makes sense, hence the "easy" question....but i hate when people ask me for easy buttons too, lol!
Thx,
Jim
body stackers.fsm
Message 5 of 8
socojim
Thanks Jordan. Yep, there is always a way...but the cost to get there varies! Appreciate the thought on the inactive members in A*, but these folks waiting on the elevator are active ( i believe), as their state is "in transit"....but i'll play with it.
Message 6 of 8
philboboADSK
Attached is your example model, modified to have the people spread out a bit when they arrive at the elevator bank.
body-stackers_1.fsm
It uses an Event-Triggered Source listening to On Traveler Arrival, then a Custom Code activity to add kinematics to the traveler to move around a bit.
When the elevator arrives, those kinematics will be re-initialized to move them from wherever they ended up to where they want to be on the elevator using the Entry/Exit Time, so this shouldn't affect the simulation results at all, just the animation.
Phil BoBo
Message 7 of 8
philboboADSK
Since all it is doing is executing custom code, I guess I could have just added the On Traveler Arrival trigger to the Elevator Bank and put the code in there without using Process Flow:
body-stackers_2.fsm
treenode kinematics = getvarnode(traveler, "kinematics");
initkinematics(kinematics, traveler, 1);
double speed = traveler.getProperty("MaxSpeed");
double acc = traveler.getProperty("Acceleration");
double dec = traveler.getProperty("Deceleration");
Vec2 dir = Vec2(uniform(-6, 6), uniform(-6, 2));
double endTime = addkinematic(kinematics, dir.x, dir.y, 0, speed, acc, dec, speed, speed, time(), KINEMATIC_TRAVEL);
dir = Vec2(uniform(-1, 1), uniform(-1, 1));
addkinematic(kinematics, dir.x, dir.y, 0, speed, acc, dec, speed, 0, endTime, KINEMATIC_TRAVEL);
Phil BoBo
Message 8 of 8
socojim
Most appreciated Phil! This is great. Thank you!
