Can anyone help me with flexSimPy?
martin_k5
martin_k5
[ FlexSim 22.2.4 ]
I tried to follow this thread:Future Python and FlexSim integration - FlexSim Community implementing the Python connection to be able to call Python script from FlexSim, but I am getting the "No module named xxx" error.
What is wrong please?
Thank you.
Martin
PyMod.py
test.fsm
kavika_faleumu
Hey @Martin K5, have you taken a look at this post "How to use Flexscript (Python) to create the data into global table"? In it I explain how to connect your Python script to Flexscript so you can execute it in a model.
martin_k5
Hi, yes I have. I have the same settings, but it does not work and I am not able to find the problem, that is why I asked for a help.
Thank you.
martin_k5
I tried to rebuild the model as attached and still getting errors.
Would you be able to help please?
Thank you.
test.fsmTestPy.py
kavika_faleumu
The external linking names are case-sensitive. You currently have
but your python script is lowercase, so it should be
It works fine after that change.
Jeanette_Fullmer
Hi @Martin K5, was Kavika F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
