Calling python functions that requires ortools fails
pcneo
Message 1 of 1
pcneo
I have set up a Flexsim model calling 3 python functions, with their return values written into labels in a token:
a) function that uses numpy (data)
    This works fine. (It first failed until I install numpy onto this python version)
b) function that checks existence of ortools (data1)
    This locates the ortools using importlib.util.find_spec("ortools") successfully
c) function that import ortools (data2)
    This fails at the statement: from ortools.sat.python import cp_model
As evidence that the 3 functions run fine or fail, the values for the 3 labels are shown.
Flexsim is started on a command prompt with PATH pointing only to 1 version of python (3.12.7).
Note: If the statement import ortools.sat.python import cp_model is moved up to the top few lines, none of the functions will run successfully.
Note: All 3 python functions run well in a standalone python environment.
The model and python file is attached. Please rename pymod1.txt to pymod1.py.
Any idea what causes the issue?
Replies (0)
