Call a row in SQL command by RowHeader?
jouky_d
jouky_d
[ FlexSim 23.2.1 ]
Hello everyone,
I need to take a row of a Table to an array. For example:
Col1Col2
Row112
Row234
By indexRow
table[2] --> [3, 4]
Or by RowHeader:
table["Row2"] -- > [3,4]
I know I can obtain the array of a column doing:
Table.query("SELECT ARRAY_AGG([Col2]) FROM table")
However, in SQL the WHERE statement is only for Column. I don't know how to call the RowHeader as a column as:
Table.query("SELECT * FROM table WHERE Row = 2)
Or by RowHeader:
Table.query("SELECT * FROM table WHERE RowHeader = "Col2")
How can we obtain the row into an array? I tought to make a for loop to obtain all values into an array, but maybe SQL statement will be optimal.
Thank you!:D
jason_lightfoot_adsk
You can try using ROW_NUMBER as described in the documentation.
jouky_d
Hello @Jason Lightfoot I tried this:
Table tab2 = Table.query("SELECT * FROM table WHERE ROW_NUMBER() = 2");
It returns an error. I can't find examples of ROW_NUMER or SQL Window Functions. I don't know where to apply those functions.
Can you write an example of it please?
As I deduced, the SQL Aggregation Functions are used on columns (e.g.: Table.query("SELECT ARRAY_AGG([Col2]) FROM table")).
But I don't know how to apply: SQL Window Functions, SQL Functions, GROUP BY.
Can you help me on understanding how and where to apply these sort of commands?
Thank you!
For example:
Table.query("SELECT ROW_NUMBER AS rownum, * FROM GlobalTable1 WHERE ROW_NUMBER=3").cloneTo(Table("resultSet"));
ROW_NUMBER_GROUP_BY_Examples.fsm
jouky_d
Thank you!:D
