Calculated parameters in Python
patryk_u2
patryk_u2
[ FlexSim 23.2.1 ]
I would like to use python code to enumerate parameters in flexsim.
In this way, I send the given parameters in this example, type and weight, to Python and it returns me a calculated value that I can use in the model.
Is there a way to do this ?
python-test.fsm:
pyfunction.py
jason_lightfoot_adsk
Your use command should only contain this:
/**external python: */ /**/"pyfunction"/**/
/** \nfunction name:*/ /**/"Flex"/**/
But you should specify the parameter types in the command gui:
patryk_u2
After he changed use command I have this error
Check that the code has been applied in the UserCommand Gui as well as the code gui, and that the python module is in the same directory as the model.
