calculate the difference between two date
sherry_x
sherry_x
[ FlexSim 21.2.4 ]
I have a table as follow, AAA and BBB are number type. I want to calculate the difference between the values in the AAA and BBB columns, with the unit in days,and write the number of days into the CCC column.
moehlmann_fe
Observer
Observer
First convert the number to a string, which you then use to create a DateTime representation of the date. These can be subtracted from each other and converted to days (datetime is the number of seconds since 01.01.1601, so to convert to days, divide by 86400).
To successfully convert to the datetime class, you have to add a delimiter between the year, month and day. Otherwise the program will interpret the first 1 of 11 to mean "January" and assume the rest is the day, leading to an error.
If you import the dates in another format the conversion might become easier.
date-conversion.fsm
sherry_x
thank you~~~~~~~
