- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 19.0.2 ]
Hi @phil.bobo,
We are trying to make an AGV layout by code using the snappoint from a dwg. The straight paths work fine, but we are having some troubles with the curved paths. Attached is a really simple layout and an example model were we use some code to create the paths. In the snappoint of the dwg we get the center, start angle and end angle. How should we use those to create the curved path at the correct location?
Thanks for your time and help,
Patrick
