Bug v25.0.2 edit container makes FlexSim to loose all contained objects
guiroehe
guiroehe
[ FlexSim 25.0.2 ]
I have this object (a couple of conveyors and dummy objects) inside a container object in a user library. It worked fine in v25.0.1. Now, in v25.0.2, clicking Edit Contents makes FlexSim to loose all 3D objects. They do not return anymore and the only solution is closing the software without saving the model.
In addition:
1. Please fix the reference for the Edit Contents tool in your help file. It is not under the "View" menu, but directly on the pop-up menu, last option.
2. The name "container" creates an ambiguity with "flow item containers" (pallets, etc.). One can see that both are derived from the same class from the perspective of a programmer/developer team; but from the viewpoint of application / user friendliness, the ambiguity makes harder to search for questions/answers or navigate in the help file, as both share the same name, not the same features or purpose in the software.
Thank you.
emily_hardySTLSK
The dev team has been notified and is investigating further.
