Bug in "Set Number in People Group" ?
SCHamoen
Advisor Advisor
SCHamoen
[ FlexSim 21.2.4 ]
I'm working on a people model and I want to have a number of equipment in the model, based on a variable in the parameters table. I can use the sampler and select a people group and I get the option to Set Number in People Group". I can also do that directly as an option in the On Set trigger. But when I do that and press reset, nothing happens. If I look at the underlying code it look like there is only code for removing objects and not for adding them. Is that correct?
Matthew_Gillespie
To use that option you need to have your maximum number already in the model. The code then makes a number of them unavailable during the model run by removing them from their group. You should see a black box drawn under the objects that are unavailable.
This option doesn't delete and create copies of the objects like the other option (Delete and Copy Group Members) because in a lot of cases in people models the objects are unique.
Matthew Gillespie
FlexSim Software Developer
