BUG Cannot getSlot from Address in 2021.0.6
sakamoto_ryosuke
sakamoto_ryosuke
[ FlexSim 21.0.6 ]
Can not getSlot from Address in FlexScript in 2021.0.6. The following code emits error.
Storage.Slot slot = Storage.system.getSlot("1-1-1-1");
The same logic works for 2020 Update1. Could you give us workaround to solve this issue in 2021.0.6 since Japanese version is released in this build? getSlot_Test_2020Update1.fsm
getSlot_Test2021_LTS6.fsm
joerg_vogel_HsH
The method getSlot occurs twice
  1. for the storage system. Parameter is the address string
  2. for a rack object. Parameters are Bay ID , Level ID and Slot ID
joerg_vogel_HsH
Ok, there is something strange with your object of LTS6 and an adjusted default scheme. The address output is missing the aisle ID. After I have added a new scheme and other floor storage racks, I could switch back to the default scheme and it worked. I did the test with LTS0.
I had such a strange behavior before. But then I inserted a new scheme and got around the problem. console-output-floorstorage-21lts0.pnggetSlot_test2021lts0.fsm
sakamoto_ryosuke
@Joerg Vogel Thank you! As you said inserting new scheme solved the problem.
