[ FlexSim 23.0.9 ]
Please check the attached file.
Even if the simulation is executed and the simulation is reset after unloading, the token remains in the unload.
If you close the process flow in this state, an error message will be displayed.
Furthermore, when I try to access the process flow from the toolbar, I get an error message and the process flow is blank.
The cause seems to occur when the item is set to current when unloading. The version we are using is 2023.0.9, but we have confirmed that it is also reproduced in the latest version 2023.1.3 at the moment.
