Break to - error
Break to - error
Amanda_Prado8XCSE
Message 1 of 1
Break to - error
Amanda_Prado8XCSE
I don't understand the behavior of my task executor.
What I want to represent is:
TE comes out loaded with 33 items from the "Scanners" queue and makes the sequential transports in the queues following the connection order. When it unloads the 33 items in the respective queues, after unloading, it loads a shelf (here represented only by the box) and takes it to the "Scanners" queue, where it will again load 33 items and take them to the next queue (now connection 2). It leaves the 33 items there, then loads a shelf and returns to the Scanners queue. This cycle repeats in a loop.
Note that in the simulation, the first transport occurs as expected, which is exactly what I expect for all the other queues. However, when the TE unloads the Shelf and goes to load another 33 scanners, the error message appears (model attached) and it loads only 1 scanner and not the 33 as expected.
I can't understand what might be happening.
Can someone help me?
Thank you very much.
Replies (0)
