Boxes assign into the tote as per availability
Pooja_inde
Pooja_inde
[ FlexSim 23.2.2 ]
Hello @Felix Möhlmann ,
As modified in the model tote is assigned with specific type.
Can we further update model with boxes placed in 1,2,3 and 4 totes whichever is available. (capacity 12 boxes each tote)
5th tote parameters will be same (no changes)
remove the assigned totes for first 4 toes'
Please find the attached model.
agv-process-flow-5-totes-type-op _Final.fsm
Thanks in advance.
moehlmann_fe
Personally, I probably would have written a small code snippet that loops through the totes and finds the first one with available space.
But I think it's more interesting and useful to get familiar with the concept to use a list. Each tote is assigned a rank and pushed to a list. Depending on the item type, the token then either pulls a tote with space and rank 5 or any other rank from the list.
agv-process-flow-5-totes-type-op-final_1.fsm
Pooja_inde
Thanks for the prompt answer.
Unable to modify operator 12 to pick and place one box at a time on the queue.
moehlmann_fe
