Binding a label to a model object
rocio_alvarez9R3F7
rocio_alvarez9R3F7
[ FlexSim 24.1.1 ]
Hello, in my model, I need to create a label called Destino that refers to a 3D element
to be able to make an AGV travel to that point in the Flow process.
If I put this: "token.pulled.as(Object).Destino" it takes the name of the object but not its location.
but I need to appear this:
The route to reach that activity in the processFlow of this process is this:
Than you.
moehlmann_fe
Observer
Observer
As long as the object is a direct subnode of the model (not placed inside a plane for example) you can use "Model.find()" to get a reference to the object by name.
Model.find("token.pulled.Destino")
rocio_alvarez9R3F7
Hi @Felix Möhlmann, Is there any other way to achieve the same thing without using planes (that the object is on the model) and without having to use Model.find?
Thank you.
moehlmann_fe
Observer
Observer
Having the object inside a plane will make Model.find() not work (at least not in this form). It is a detriment not a requirement.
Where does the "Destino" label on the pulled object come from? Maybe you can replace that with a pointer already.
Another option would be to create a lookup map that links the name to a pointer to the object.
rocio_alvarez9R3F7
In my model the "Destino" label refers to these queues.
It is a dynamic process where the queue that will be the destination changes depending on where the item enters, that is why I cannot go directly with the pointer.
My question was if knowing that the object that is going to be the "Destino" (the image tails) is in the model is there another way (FlexScript syntax) to express Model.find(token.pulled.Destino).
Thanks.
moehlmann_fe
Observer
Observer
No, the only other way would be to prepare some kind of lookup method in advance, like I suggested doing with a map.
To get a reference to a node by name you use the find() method. (Technically there is also the "node()" command but that is just the deprecated version of find().)
rocio_alvarez9R3F7
Thank you for your answers.
kind regards.
