[ FlexSim 19.1.1 ]
I'm trying to create a little model on LWBS (Leave Without Being Seen) patients with 19.1.1 FlexSim version. I try some methods but I can't replicate the process of the old versions of FlexSim. For example, when I open the trigger windows of a waiting room, I can't send a delayed message to the waiting room, even if there is a "on message" trigger.
So I try to test an other process, wich is :
- Patients arrive and walk to the waiting room
- I use a "split" step to have two tokens. The first modelize the patient flow, the second (on the left) modelize if the patient will stay or not.
- So, the "left part" process is :
1°) after 30 minutes, the patient ask himself "should I stay or not ?"
2°) He has 80% chance to stay, 20% chance to leave
3°) If he stay, he repeat the same question in 30 minutes
4°) If he want to leave, there is an other test and here is the problem :
The "custom code step" are used to write on the token label the patient location ("Waiting Room";"Exam Room"...) and the second "Decide step" on the left is used to check if the patient is still on the waiting room.
If he is, the patient leave, but if he is not, it means he is in the exam room so he doesn't have to leave, so I delete the token.
The problem is : when we split a token in two parts, the two new tokens are linked (same splitID), but I thought that when I write something on the label of one of them, the second is updated. But it is not the case, so I can't chek my patient's location on the "left process". Actually, in my model, during his exam, my patient leave because the "left token" is not updated.
So my question is :
is there a code instruction that allows me to change the label of the token that has the same splitID than the token wich is triggering the custom code to update my patient location ?
Thanks for your help !
